Warning message
MPLS VPN driving me mad!
I am testing MPLS VPNs in the lab, with a view to rolling it out in the core provider network. I am having difficulty connecting a single VPN. Everything looks as it should. I have two sites pointing a default route out. I have all the VRF information configured. The MP-iBGP sessions seem to work and the VRF routing tables are holding all the routes i expected, i just cannot ping across from one site to the other. Core label switching works okay, and the static routes are being redistributed. I am also redistributing connected and static subnets within the BGP address-family. Does anyone have any ideas so i can finally get a nights sleep, thanks Ian
bturnbow Wed, 10/16/2002 - 23:13
First make sure that MPLS is running on all interfaces where the traffic will pass. Sh mpls int . It should read operational yes.
You need to have a /32 route on all routers in the MPLS cloud for your PE routers. I use a loopback address that is injected into my IGP. Even non MPBGP routers need to have the specific /32s.
One other tip, make sure you have your MTU set to 1526 or above on Ethernet interfaces 1518+4+4.
