Warning message
3660 as the dialup router
Oct 9th, 2002
I did post this a few months back. Got back answers from tepatel. But Im still not clear and would like to post it again.
I have a new 3660 router and want to use it for users to dial in and access our services, like e-mail, Internet and athoer application.
Im currently using a 2511 and analog POTS lines connected to external modems. I want to get rid of this 2511 Cisco router, the analog lines and external analog modems. We use RADIUS for dial up access
I want to replace this 2511 with 3660 and use one T1 or E1 digital line, use digital modems (NM-32DM) where users dial into and use RADIUS.
I just need advice on which particular hardware I need to buy and a sample configuration will be very much appreciated.
Below is the current conficuration we have on one our 2511 router:
SuvaDialupRouter01#sho conf
Using 2257 out of 32762 bytes
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname SuvaDialupRouter01
aaa new-model
aaa authentication local-override
aaa authentication login use-radius radius local
aaa authentication ppp use-radius if-needed radius local
aaa authorization exec radius local if-authenticated
aaa authorization network radius local if-authenticated
username test password 7 0010161510
ip domain-list govnet.gov.fj
ip domain-list itc.gov.fj
ip name-server 10.1.85.156
ip name-server 10.1.85.158
async-bootp dns-server 10.1.85.156
async-bootp nbns-server 10.1.85.156
chat-script cisco-default ABORT ERROR "" "AT Z" OK "ATDT \T" TIMEOUT 30 \c CONNc
interface Ethernet0
ip address 10.1.85.2 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface Group-Async1
ip unnumbered Ethernet0
no ip mroute-cache
encapsulation ppp
no ip route-cache
keepalive 10
async dynamic address
async mode interactive
peer default ip address pool dialin
no cdp enable
ppp reliable-link
ppp authentication chap use-radius
group-range 1 16
ip local pool dialin 10.1.86.1 10.1.86.16
ip default-gateway 10.1.85.22
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.85.22
radius-server host 10.1.85.156 auth-port 1645 acct-port 1646
radius-server key RoLalabalavu29
line con 0
line 1 16
autobaud
autoselect during-login
script dialer cisco-default
login authentication use-radius
modem InOut
transport input all
flowcontrol hardware
line aux 0
line vty 0 4
password
end
utawakevou Thu, 10/10/2002 - 14:50
Thank you very much for the reply. In fact I already got a 3660 with two slots (1 & 2) where two 4 port serial Network module (NM-4T) is connected to these slots.
When you say NM-1FE1CE1 do u mean NM-1FE1CE1B or NM-1FE1CE1U. Please clarify.
Anyway, I have already got the 3660 in use. Does this means that I still need to buy NM-1FE1CE1 or I just buy a T1/ISDN-PRI Network Module (NM-1CT1-CSU) and
a 24 port Digital Modem Network Module (NM-24DM).
Below is the result of the show diag command I issue on our current 3660 router.
ITC_Router_3660#sho diag
3660 Chassis type: ENTERPRISE
c3600 Backplane EEPROM:
Hardware Revision : 1.0
Top Assy. Part Number : 800-04740-02
Board Revision : C0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : HAD04471SGX
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Chassis Serial Number : JAB0549801G
Chassis MAC Address : 0007.85bf.34c0
MAC Address block size : 112
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Fab Part Number : 28-2651-02
Number of Slots : 6
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 C8 41 01 00 C0 46 03 20 00 12 84 02
0x10: 42 43 30 80 00 00 00 00 02 02 C1 8B 48 41 44 30
0x20: 34 34 37 31 53 47 58 03 00 81 00 00 00 00 04 00
0x30: C2 8B 4A 41 42 30 35 34 39 38 30 31 47 C3 06 00
0x40: 07 85 BF 34 C0 43 00 70 C4 08 00 00 00 00 00 00
0x50: 00 00 85 1C 0A 5B 02 01 06 FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 0:
C3600 Mother board 1FE(TX) Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : JAB05440FND
Processor type : 34
Top Assy. Part Number : 800-05293-04
Board Revision : C0
Fab Part Number : 28-3234-02
Deviation Number : 65535-65535
Manufacturing Test Data : FF FF FF FF FF FF FF FF
RMA Number : 255-255-255-255
RMA Test History : FF
RMA History : FF
Field Diagnostics Data : FF FF FF FF FF FF FF FF
0x00: 04 FF C1 8B 4A 41 42 30 35 34 34 30 46 4E 44 09
0x10: 34 40 00 DA C0 46 03 20 00 14 AD 04 42 43 30 85
0x20: 1C 0C A2 02 80 FF FF FF FF C4 08 FF FF FF FF FF
0x30: FF FF FF 81 FF FF FF FF 03 FF 04 FF C5 08 FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00
Slot 1:
Mueslix-4T Port adapter, 4 ports
Hardware revision 1.1 Board revision J0
Serial number 26536025 Part number 800-02314-02
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
0x20: 01 54 01 01 01 94 E8 59 50 09 0A 02 00 00 00 00
0x30: 98 00 00 00 01 11 29 00 00 05 FF FF FF FF FF FF
Slot 2:
Serial number 26553974 Part number 800-02314-02
0x20: 01 54 01 01 01 95 2E 76 50 09 0A 02 00 00 00 00
0x30: 98 00 00 00 01 10 17 00 00 05 FF FF FF FF FF FF
Thanks for your help
sloos Fri, 10/11/2002 - 01:11
  • Cisco Employee,
You are right. If you just need a T1 or E1 interface (and no fastethernet), you can go for the NM-1CT1 or the NM-1CT1-CSU or NM-1CE1U / NM-1CE1B.
Whether you need E1 or T1 depends on the country you live in. If you need E1, check with the provider on whether you need balanced or unbalanced.
More info on an E1/T1 network module is on CCO. Here is an example about the
1port FE, E1 netw module: http://www.cisco.com/warp/public/107/hw-1fe-e1.shtml
All network modules are on:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/ovrnetm.htm#21057
and off course you need the modem module nm-30dm or nm-24dm
utawakevou Fri, 10/11/2002 - 14:00
Thank you so much for the help. I think Im clear now as to what I can buy for my dialup solution.
regards
