10-16-2002 09:48 AM - edited 03-09-2019 12:41 AM
I have a problem with connectivity with a cisco router and pc
anywhere. All is fine when no security measures are taking on the
router, but when applying the access list, I can only connect to
machines when coming from outside the LAN, but can not see any remote
machines using pc anywhere when trying to contact a machine outside
the LAN. I have allowed ports 5631 and 5632 access, which is what
Symantec says pc anywhere uses. All works great with out the routers
ACL list applied. Has anyone else maybe had this type of problem with
pc anywhere??
Should maybe I apply an access list to E0 connected to the inside LAN??
There is no list in place at the moment.
I have this list applied to s0, connecting to the outside, and it seems
to work for access from outside. Just the inside network can not get out
using pc anywhere.
access-list 101 permit tcp any any established
access-list 101 permit tcp any 10.0.0.1 0.0.0.255 eq pop3
access-list 101 permit tcp any 10.0.0.1 0.0.0.255 eq www
access-list 101 permit icmp any 10.0.0.1 0.0.0.255
access-list 101 permit tcp any 10.0.0.1 0.0.0.255 eq 5631
access-list 101 permit udp any 10.0.0.1 0.0.0.255 eq 5632
access-list 101 permit udp any 10.0.0.1 0.0.0.255 eq domain
access-list 101 permit tcp any 10.0.0.1 0.0.0.255 eq smtp
access-list 101 permit tcp any 10.0.0.1 0.0.0.255 eq telnet
access-list 101 permit tcp any 10.0.0.1 0.0.0.255 eq 5900
access-list 101 deny ip any any log
Has anyone else had trouble with pc anywhere that you know of with
regards to access through a cisco router? symantac also mentions that pc anwhere uses sap announcements.
Thank you
10-16-2002 11:18 AM
I think the acl is ok.
The problem could be related to Pc Anywhere versions? i found
take a look of this to see if it helps you.
