Warning message
questions on Pilot Points and cheap ACD
Oct 17th, 2002
First I am trying to set up a cheap ACD solution for a Tech support 1-800 number with 4 support techs and one admin, In theory the Admin will take the calls then transfer it to an availalble Tech, however if she is not at her desk or is busy then It needs to roll over to the techs where they can answer the call, if they are all busy it can then go to voice mail where they can leave a message. So what I did was set up two Pilot Points one for the Admin and one for the techs and I have the Admins pilot point hunting to the Tech Pilot Point. and I then will install the Web Attendant software on everyones PC.
Now the Question is: Is there a better way to do this? (without getting ICD) and is there a way to get reports on how many calls went to the Pilot Point, who is logged in, and that sort of ACD Admin type of reports?
and Finally I set this up to test on a working system, however my pilot points are not working at all, I get a fast busy when I try and call the first Pilot point, all the Partitions and Calling search spaces are set up right, I have stopped and started the Telephony Call Dispatcher Service, Do I have to reset something else to make those pilot points start working?
Thanks In Advance
Ken
mciarochi Thu, 10/17/2002 - 07:06
In 3.1(3a) the pilot points must auto-register (there's no device pool option). Is that working correctly? Just a thought.
kgroves42 Thu, 10/17/2002 - 07:14
I did not assoicate those route points with the user ac. that is why I was getting a busy when I called those route points
thanks
Ken
