Warning message
bwalchez Thu, 10/24/2002 - 07:31
I am sure the ppp multilink can be CEF switched although I am not able to provide you with a direct link to confirm this.
shipsak Sun, 10/27/2002 - 19:06
A way around this that I know will work would be to run each link individually, if this is possible. This will only work if all of the lines are equal in speed.
As far as CEF supporting ppp, i found this link after a quick search.
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
Under the heading
Load balancing with CEF for IP
Hope this helps
Scotth
