Warning message
Error on VPN 3015 when VPN client trying to connect
Oct 19th, 2002
Trying to connect to our VPN concentrator and I get this error. I just started configuring our concentrator not sure if I did it right.
1 10/19/2002 14:22:50.400 SEV=5 IKEDBG/64 RPT=55 64.173.199.201
IKE Peer included IKE fragmentation capability flags:
Main Mode: True
Aggressive Mode: False
3 10/19/2002 14:22:50.620 SEV=4 IKE/165 RPT=25 64.173.199.201
Group [ExternalVPN]
Client IKE Auth mode differs from the group's configured Auth mode
5 10/19/2002 14:22:50.620 SEV=4 IKEDBG/65 RPT=50 64.173.199.201
Group [ExternalVPN]
IKE AM Responder FSM error history (struct &0xa3dddc8)
<state>, <event>:
AM_DONE, EV_ERROR
AM_BLD_MSG2, EV_CHK_PROPOSAL
AM_BLD_MSG2, EV_TEST_CERT
AM_BLD_MSG2, EV_SECRET_KEY_OK
thanks
edadios Sun, 10/20/2002 - 17:12
  • Silver, 250 points or more
The cisco software client by default uses the xauth mode for authentication. Make sure the client with xauth ike is active and on top of the list under the CONFIG| SYSTEM| Tunneling protocol | IPSEC | IKE PROP.
Otherwise, see if looking at this sample config helps you (check the concentrator config only) : http://www.cisco.com/warp/customer/471/vpn3k_linux_7203.html .
