VPN Client 3.6.2A to PIX 501 - cannot ping inside interface or access PDM
Oct 21st, 2002
I have built my tunnel and I can even ping a host on the inside.
36: Outbound ICMP echo reply (len 32 id 2 seq 7425) 192.168.3.100 > 192.168.3.100 > 192.168.12.1
37: Inbound ICMP echo request (len 32 id 2 seq 7681) 192.168.12.1 > 192.168.3.100 > 192.168.3.100
38: Outbound ICMP echo reply (len 32 id 2 seq 7681) 192.168.3.100 > 192.168.3.100 > 192.168.12.1
39: Inbound ICMP echo request (len 32 id 2 seq 7937) 192.168.12.1 > 192.168.3.100 > 192.168.3.100
40: Outbound ICMP echo reply (len 32 id 2 seq 7937) 192.168.3.100 > 192.168.3.100 > 192.168.12.1
41: Inbound ICMP echo request (len 32 id 2 seq 8193) 192.168.12.1 > 192.168.3.100 > 192.168.3.100
42: Outbound ICMP echo reply (len 32 id 2 seq 8193) 192.168.3.100 > 192.168.3.100 > 192.168.12.1
Problem, is that I cannot access the PDM or even ping the inside interface.
Here is my current config.
Any ideas? Thanks!
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any time-exceeded
access-list 100 permit tcp any host x.x.x.x eq ftp
access-list localtovpnclient permit ip 192.168.3.0 255.255.255.0 192.168.12.0 255.255.255.0
access-list nonatinside permit ip 192.168.3.0 255.255.255.0 192.168.12.0 255.255.255.0
pager lines 24
logging on
logging trap debugging
logging history debugging
interface ethernet0 10baset
interface ethernet1 10full
icmp permit any outside
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.224
ip address inside 192.168.3.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnclientpool 192.168.12.1-192.168.12.99
pdm history enable
arp timeout 14400
global (outside) 1 x.x.x.x
nat (inside) 0 access-list nonatinside
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.x.x 192.168.3.100 netmask 255.255.255.255 0 0
access-group 100 in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.3.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
no floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
service resetinbound
crypto ipsec transform-set mytransform esp-des esp-md5-hmac
crypto dynamic-map mydynmap 10 set transform-set mytransform
crypto map mymap 100 ipsec-isakmp dynamic mydynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool vpnclientpool
vpngroup vpn3000 dns-server 142.77.2.36
vpngroup vpn3000 split-tunnel localtovpnclient
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
telnet 192.168.3.100 255.255.255.255 inside
telnet timeout 5
terminal width 80
andre.frost Mon, 10/21/2002 - 22:47
you can find that in every PIX document that you never can ping the opposide interface of the PIX but all other hosts in the net, if allowed.
stakano Tue, 10/22/2002 - 05:36
I should be able to access the PDM if I'm tunnelled in right?
edadios Tue, 10/22/2002 - 22:46
  • Silver, 250 points or more
No, You can not reach the inside interface directly if you are coming from the internet.
