Warning message
routing issue with PPP multilink on 7513
Oct 22nd, 2002
Dear all,
I'm having the following problen when I configured 7513 for E1 multilink (2xE1); first in order to ping the P2P interface I need to disable route-cache
(no ip route-cache distributed) under both serail interfaces.
When I add this command I can ping the other side only from the directly connected router. All the others routers on the network can't access the other router on the other side.
interface Serial5/0/5:0
description * Uplink
no ip address
no ip directed-broadcast
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 1
interface Serial5/0/4:0
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 1
interface Multilink1
description *
ip address 10.10.10.1 255.255.255.252
no ip route-cache cef
no ip route-cache
load-interval 30
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 1
same config on the other side.
Please note that the following two line below (under multilink interface) are added by default when you add no ip route-cache distributed (under the serial interfaces)
no ip route-cache
Routing part
Routing entry for 10.10.10.10/32
Known via "isis", distance 115, metric 50, type level-2
Redistributing via isis
Last update from 10.10.10.1on GigabitEthernet3/0/0, 01:48:30 ago
The ISIS is able to redistribute the the route to the other peers, but the peer is not able to ping this network. Default route is also defined on the customer network.
mljohnson Wed, 10/23/2002 - 14:21
Not sure I understand why the update from 10.10.10.1 was on a G-Ether; you should have seen the IP address of the G-Ether, instead. If you can ping point-to-point, then the MPPP stuff must be OK; so I'd focus on the routing. Using either the trace command or "sh ip route", you can see what the problem might be at each hop beyond the directly connected PPP device.
amin.amor Fri, 10/25/2002 - 06:09
The problem was IOS bug. CEF and MLPPP is not working properly,
the routing is ok. check this out CSCdy43576 this is a new bug sep02.
