LMI Autosense is not working
I have a frame relay connection into a serial interface on a 7206 router running IOS 12.2(12). The interface is up but until I manually configure the LMI type, the line protocol stays down. I thought LMI autosense was enabled automatically but this does not seem to be the case or it is not working. Is there something else that I need to do to make autosense work or are there conditions where it will not work?
reinke Tue, 10/22/2002 - 21:56
Check wheather lmi is running at all (show frame-relay lmi ...). You should see outgoing and incoming lmi messages.
Maybe lmi is not running at all because it is not activated on the frame-relay switch or the switch do not provide a dlci via lmi.
Edgar
