Warning message
Telnet session Freeze
Oct 22nd, 2002
I have a problem with a VPN PE router. Qhen I tried to access to remote location thought telnet session, remote route answer OK, but when I try to work with it, the telnet session is freeze.
My customer didnt work, but when I test the connection with ping and trace, this is OK.
I changed the customer router and the behaivior is the same. I test the same router with a second link and it works fine. The link is error free
My link is nx64 trough E1 controller on my 7513.
Any idea?
Pablo Domínguez
[email protected]
Mexico
rsissons Tue, 10/22/2002 - 16:28
  • Bronze, 100 points or more
I would try using a different telnet client. I have seen problems where some clients freeze rather than the router itself which does not appear to be the case if you can still ping it.
