Warning message
IOS and vlan routing
Oct 23rd, 2002
Hi i have a router with 3640 with c3640-is-mz.121-2.T.bin IOS, it work fine for video H.323, voIP and data. But in the LAN i have vlan with ISL and switch 3524XL and principal 6506Catalyst, but my IOS of the router it don´t support virtual ethernet interface with isl for vlan routing, the 6506 is layer 2. What IOS can support isl and maintain the other features
juan-santamaria Fri, 11/15/2002 - 12:23
only i can to make intervlan routing using isl and sup interface with router 2600 and catalyst 3524.it need fast ethernet interface in the router or I can to make that with 10M ethernet interface
pedjasim Mon, 11/18/2002 - 03:13
IOS is not the problem.
The solution for your problem is to buy some card with FastEthernet port, because trunking isn't possible on ports that are not FastEthernet.
