Warning message
Baystack 450-24T Catalyst 3548
Answered Question
Oct 25th, 2002
How can I get a connection via Gbic between these differents switches. Both switches are not using Vlan but are use like a hub.
Which config should I enter into both catalyst. (full duplex, negociation...)
Correct Answer by MARIO PAIVA about 14 years 10 months ago
No the gbic on the c3548 isn't 100/1000, it is only 1000 Mbps. So you never will be able to connect the bs450 to the C3524, if you not buy an gbic 1000 Mbps to the bs450.
MP
Should not put autonegotiate in both sws and no full duplex. Set same speed in both.
MP
Overall Rating: 4 (2 ratings)
Correct Answer
MARIO PAIVA Fri, 10/25/2002 - 03:52
MP
jvignault Fri, 10/25/2002 - 04:15
I've tried but it still doesn't work. Is there something else to add into the c3548 ?
jvignault Fri, 10/25/2002 - 04:41
Ont the Baystack the line is up but not on the catalyst. The speed on the c3548 is 1000 and 100 on the baystack.
How can I change the speed on the c3548 ?
Correct Answer
MARIO PAIVA Fri, 10/25/2002 - 04:55
MP
