Warning message
ICS7750 patch/service pack roadmap
Oct 25th, 2002
I have an ICS7750 that I have been playing with an hope someone can help.
I ghosted the spe, applied 2.5 system manager, discovered card, applied
v2Udate, applied win-os-upgrade.200-2.3, installed call manager publishe and then applied win-SQLservicepack4.1-001 and SQL7-MS02-056. All went well, I then re-ghosted spe to be used as subscriber and installed 2.5 core software and then used ICSCONFIG to discover the card. All goes well. I then attempt to install CAll Manager as subscriber with no success. The install log would indicate that it is searching for sql sp3. I can find nothing in the documentation that would indicate that you cannot apply service pack 4. What am I doing wrong???
