10-25-2002 06:15 AM - edited 03-12-2019 09:18 PM
Hi Specialists.
since Integrating the ADS inside of a W2k-Domain into a redundant callmanager group plus cti application over tapi is VERY complicated to troubleshoot, i've been wondering if there is some detailed documentation available about all the user/authentication stuff , and which ways it goes.
so for instance :
a) cti-service uses user / pw from <location in registry>, and ask the DataConnection Directory.
b) dcd can be administered with application <xy> by typing in user / pw <zz>
c) dcd then forwards the request to ldap, configured at <location in registry>
d) the ads-plugin uses ......
the reason is : i often have problems with locked accounts / not working tapi-link etc., but i is almost IMPOSSIBLE to debug the whole thing. all i can do is: unlock the accounts, reset ALL passwords and restart the servers.
DETAILED information about all the connections and requirements would be _VERY_ appreciable.
can you help ??
thanks in advance, gerhard
10-25-2002 10:17 AM
You might try the links below, hopefully they are detailed enough, if not, there are some pretty pictures in them with lots of arrows. :)
http://www.cisco.com/warp/public/570/avvid/voice_ip/cti/downloads/CTI_Apps.pdf
http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/3_1/tapi/tap5.pdf
Rick
10-28-2002 12:38 AM
thanks rick,
these documents give good overview...
bye
g
10-28-2002 01:15 AM
good docs rick.
thanx.
siddharth.
