Warning message
3640 E1 IMA problem
Oct 27th, 2002
Please help. I cannot get IMA group up.
This is result of sh ima int
Interface ATM2/IMA1 is down
Group index is 1
failure status is blockedNe
Active links bitmap 0x0
IMA Group Current Configuration:
Tx/Rx configured links bitmap 0x1E/0x1E
Tx/Rx minimum required links 1/1
Maximum allowed diff delay is 25ms, Tx frame length 128
Ne Tx clock mode ITC
Test pattern procedure is disabled
IMA Group Current Counters (time elapsed 0 seconds):
-1 Ne Failures, 1629593548 Fe Failures, 0 Unavail Secs
IMA Group Total Counters (last 0 15 minute intervals):
IMA link Information:
Link Physical Status NearEnd Rx Status Test Status
ATM2/1 down notInGroup disabled
ATM2/2 down notInGroup disabled
ATM2/3 down notInGroup disabled
ATM2/4 down notInGroup disabled
- if i delete IMA group then member fhisical interfaces are up
- in logs ther is
IMA reset group ATM2/IMA1
IMA: IMA interface is still waiting for a free channel.
every 10 minutes. I do not have live PVC channels in that group. Is this a problem maybe. Shouldnt't IMA group be up withoput any PVC
Thanks a lot
dragan.skundric... Mon, 10/28/2002 - 12:25
Well I've solve it. I've had ATM2/0 interface outside group and enabled, than I've had ATM2/1-4 in IMA group with problems, and ATM2/5-7 interfaces ALSO ALIVE. In one document I've found that NM-8E1-IMA on 3640 supports only four IMA groups and that unassigned ATM channel ocupies one IMA group so basically I was left with no available IMA groups.
After shutting down of ATM2/5-7, IMA group came up.
