10-31-2002 12:43 PM - edited 03-02-2019 02:33 AM
When checking the device attributes in RME 3.4 to a c3548XL switch that has a TACACS+ login, it comes back with the TACACS+ password is incorrect. I debug the authentication on the switch and see that the connection times out without ever checking the password. I can telnet to the switch and the username and passcode works fine.
10-31-2002 12:59 PM
If you're using Check Device Attributes, then one way to verify this is to do an Export to File and then see if the device credentails stored in the db are indeed correct or not. If they are correct, then Check Device Attributes is not working properly and you may want to do a search on CCO Bug Toolkit to see if there's any open issues for this.
10-31-2002 01:52 PM
Yes, I am using Check Device Attributes. I checked the exported file and the user name and password are correct.. I will check for bugs.
10-31-2002 01:42 PM
Make sure that once you log into the switch through TACACS+ you're presented with a carrot ">" after the hostname. If you've changed the prompt on the switch without including the ">" at the end of the prompt CiscoWorks has no idea it has completed the login and will eventually fail.
10-31-2002 01:55 PM
The prompt is terminated in a ">" after login.
10-31-2002 03:19 PM
Are you using Solaris 8 by any chance ? There is a bug that you may be hitting if you are.
11-01-2002 05:49 AM
I am using Windows 2000 Professional Service Pack 3.
11-01-2002 10:46 AM
Just to give you a heads up, Windows 2000 Service Pack 3 is not currently supported by LMS 2.1
