Unity Client to Pix inside and dmz networks
Answered Question
Nov 1st, 2002
Are there any problems that would prohibit a Unity Client to start connections to hosts on the pix inside and pix dmz networks at the same time?
Can you provide a link that describes the PIX side of the configuration for access to both networks not just the inside network?
Correct Answer by gfullage about 14 years 9 months ago
Whoops, yep sorry, brain fade on my part, disregard my first email. Your configuration would look like this:
ip address inside 10.1.1.1 255.255.255.0
ip address dmz 172.16.1.1 255.255.255.0
ip local pool vpnpool 192.168.1.1-192.168.1.254
nat (inside) 0 access-list nonatinside
nat (dmz) 0 access-list nonatdmz
access-list nonatinside permit ip 10.1.1.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list nonatdmz permit ip 172.16.1.0 255.255.255.0 192.168.1.0 255.255.255.0
Hope that helps.
Overall Rating: 5 (1 ratings)
gfullage Sat, 11/02/2002 - 17:59
  • Cisco Employee,
There isn't any problems with this, you just have to make sure you bypass NAT for traffic from both interfaces going to your VPN pool of addresses. The PIX will take care of the routing, etc.
For example, your config would look like this:
access-list nonat permit ip 10.1.1.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list nonat permit ip 172.16.1.0 255.255.255.0 192.168.1.0 255.255.255.0
Hope that helps.
aemr Sun, 11/03/2002 - 11:13
Very Helpful, Thank you!
Would I also need a nat (dmz) 0 access-list nonat statement for the DMZ hosts to bypass nat?
Correct Answer
gfullage Sun, 11/03/2002 - 16:12
  • Cisco Employee,
Hope that helps.
aemr Mon, 11/04/2002 - 12:36
That helps very much.... Thank you!
