Warning message
INSTALL FLASH
Nov 1st, 2002
I have a switch (2924) that has no flash in it. When I boot I get this message:
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
load_helper
boot
dir on flash-init shows nothing. I understand that TFTP is used to get the IOS image down, but how do I get TFTP from here. I can't figure out the way to configure the switch to use TFTP for it's image.
Any help is very appreciated
thisisshanky Fri, 11/01/2002 - 17:08
  • Purple, 4500 points or more
I doubt if the this will work. I dont have a 2900 right now with me to try this out....but you could try this...
at the switch: prompt...try
switch: boot tftp:\\ x.x.x.x\
Hopefully if this works....you are in luck...Again... i am not sure abt this....command being supported.
