Warning message
PIX VPN Negotiation Messages
Nov 2nd, 2002
Can anyone help me decipher what these debug crypto isa messages mean, and how to go about correcting the situation?
<dest. ip> = address being contacted
<src. ip> = address initiating contact
The source device is a pix 501 connected to my cable modem at home. The destination is another pix 501 connected off of a dmz port on a cisco 2600 series router.
--Andy
VPN Peer: ISAKMP: Added new peer: ip:<dest. ip> Total VPN Peers:1
VPN Peer: ISAKMP: Peer ip:<dest. ip> Ref cnt incremented to:1 Total VPN Pee1ISAKMP (0): beginning Main Mode exchange
crypto_isakmp_process_block: src <dest. ip>, dest <src. ip>
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 1 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash MD5
ISAKMP: default group 2
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_FQDN
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): speaking to another IOS box!
ISAKMP (0): ID payload
next-payload : 8
type : 2
protocol : 17
port : 500
length : 26
ISAKMP (0): Total payload length: 30
ISAKMP (0): retransmitting phase 1...IPSEC(key_engine): request timer fired: co, (identity) local= <src. ip>, remote= <dest. ip>,
local_proxy= <src. ip>.0/255.255.255.0/0/0 (type=4),
remote_proxy= <dest. ip>.0/255.255.255.0/0/0 (type=4)
ISAKMP (0): deleting SA: src <src. ip>, dst <dest. ip>
ISADB: reaper checking SA 0x80963dd0, conn_id = 0 DELETE IT!
gfullage Sun, 11/03/2002 - 16:24
  • Cisco Employee,
Without seeing the configs or the actual src and dst IP addresses, it's a little hard to figure out, but what it looks like is the remote PIX is trying to initiate a tunnel negotiation with this PIX. The first ISAKMP packet comes in, this PIX checks it, agrees on the parameters of the negotiation, then sends an ISAKMP packet back to the remote PIX. Nothing happens after this and a short time later, this PIX retransmits the packet. Again it gets nothing back, and it retransmits again.
What's possibly happening is that the ISAKMP packets from this PIX are not reaching the other one. Is the other one the one behind the 2600? Make sure it is allowing UDP port 500 packets through. Make sure the remote PIX has the "sysopt connection permit-ipsec" command in it. Can you run the debugs on the remote PIX and see if it loks like it's receiving any ISAKMP packets? Are you doing NAT on the 2600, and if so, do you have a static translation set up for the outside address of the PIX?
