Warning message
session target trunk
Nov 5th, 2002
i have a router that is accepting DID's 44XX that get sent to call manager via the session target ipv4:X.X.X.X command.
I need to use the same router to send other DID's 33XX to another vwic on the same router that trunks to a pbx. This trunk is configured as
ds0-group 0 timeslots 1-24 type e&m-wink-start
what would be the session command to enable this?
would i also have to create a pots dial peer for this port? so when the digits come in a voip dial peer has to tell them to use the outgoing dial-peer? confused.
or do i just use the outgoing dial peer? so when the provider sens those 4 digits to the router the router will use its pots dial peer to send them back out again?
pacameron Wed, 11/06/2002 - 15:07
  • Silver, 250 points or more
What you are trying to do is called hairpining.
If you have 2 DID ranges coming in, then you would point one range to the VOIP dial peer and the other range to a POTS dial peer. In your case, the dial peers would be something like this :
dial-peer voice 1 voip
destination-pattern 44..
codec g711ulaw
ip precedence 5
dtmf-relay h245-alpha
dial-peer voice 2 pots
destination-pattern 33..
port 1/1:0
prefix 33
the first dial peer will send the calls to the CM while the second dial peer will send calls in the range 33XX to the second T1 port (T1 1/1). The prefix command is used to put the leading 33 back on the digit string, as by default POTS dial peers strip explicitly matched digits.
