Warning message
IKE Preshared Key in clair text
Nov 6th, 2002
When I use the command "crypto isakmp key balbla add 1.1.1.1" and then make a show run
The key stay in clair text. Do somebody know how to make it unvisible like in a PIX?
Gael
Nairi Adamian Thu, 11/07/2002 - 02:48
  • Cisco Employee,
There was a bug open for this issue. The bug id is
CSCdt27453 - isakmp password is displayed in plain text in the show tech output
It was resolved in version 6.0.1.
Hope this helps,
-Nairi
gclavadetscher Fri, 11/22/2002 - 03:19
Thanks for your advice,
Do you know if it's possible to do the same for a Router.
I'm using the IOS 12.2 and the isakmp password is also displayed in plain text.
Cheers, Gael
