Warning message
Network Management Software Tools for CallManager / VoIP?
Nov 7th, 2002
We are about to rollout CallManager in a few months. Can anyone recommend any network management software tools that might help me with CallManager and other Cisco network devices as well? We just need some sort of software that will help us manage out network. I've read a lot of good reviews about the Solarwinds tools, but is there anything out there that might be specific to VoIP or CallManager?
Any suggestions would be greatly appreciated. Thanks.
Overall Rating: 5 (1 ratings)
8gsiaw Thu, 11/07/2002 - 09:03
Prognosis from IR is a good one. http://www.prognosis.com. However, checkout good old ciscoworks 2k for voice monitoring - http://www.cisco.com/en/US/products/sw/cscowork/ps2433/index.html
Also another good lead is the associate avvid vendors. There are quite a few good ones in there - http://www.cisco.com/pcgi-bin/ecoa/Search?choose_category=EVBU&the_examples=Select%20All&the_examples1=Select%20All
Good luck.
svpotdar Wed, 12/04/2002 - 22:37
If you are really VoIP call Quality/CallManager specific try visiting www.netiq.com They offer a good range of products for VoIP Pre and Post Deployment.
and they have demo downloads. worth trying. I have the contacts let me know
shruti
