HSRP on router and firewall
Nov 7th, 2002
Juz wondering whether i could run HSRP on a pix firewall? if so can i run HSRP on a router and pix firewall so that i can use the router as a hot standby for the pix firewall
regards,
jimmy
thisisshanky Thu, 11/07/2002 - 15:25
  • Purple, 4500 points or more
No you cannot, Only way to do this is to use a PIX and use either a failover cable, or to use LAN based failover for the PIX.
father Thu, 11/07/2002 - 19:21
PIX not support HSRP because not use IOS software.But you can use failover/stateful failover on PIX.Required 2 unit of PIX with same hardware & software version.
Vipul.
