Warning message
ISL/802.1Q Trunking
Nov 8th, 2002
Stupid one, can you trunk three switches together in a triangle (full loop) style topology??
Ack that you can trunk in a tree or star type config but would like to achieve a loop to avoid the pain of tweeking Spanning-Tree
amavrin Fri, 11/08/2002 - 04:39
Of course you _can_ , but you should consider the consequences of Spanning Tree.
makkers Fri, 11/08/2002 - 07:20
Thanks thought so but dont have the environment to test. I thought that a trunk port was removed from the spanning tree instance therefore not a consideration.
