Warning message
VPN Concentrator address management
Nov 13th, 2002
I have VPN concentrator with two groups defined. What I want to do is to use DHCP address assignment for one group, and local pool for the other group. If I use DHCP or local pool for both groups, that works. But, if I assign one pool of addresses for one group, and for the other group pool is empty (which means use DHCP), I still have DHCP addresses for both groups.
Can someone tell me, if I can combine DHCP and local pools per group, or I have to use one address assignment for all groups in the VPN concentrator?
Thanks in advance,
Sasa Vidanovic
Nelson Rodrigues Mon, 11/18/2002 - 21:42
  • Cisco Employee,
No, you cannot combine address assignment methods.
Address Assignment is for the whole concentrator , not per group.
In your case DHCP always takes higher precedence over Address pools (global or per-group address pools).
