Warning message
APs Fail to Reconnect After a Power Failure
Nov 13th, 2002
I have some AP-350's failing to reconnect to their parent switches - Cat 5000's and Cat 5500's - after a power failure and resumption. Firmware is 11.10T. It looks like it consistently happens when power is fed from the in-line power injector but I'm not sure. Has anyone seen this before?
tepatel Thu, 11/14/2002 - 09:35
  • Cisco Employee,
Are you using in-line power or power injector?
Does AP comeup at all with in-line power?
There is one issue reported where re-connect of eth cable to AP does resolve the issue..
Try to use the power injector and see the results
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
