Warning message
800 Router dialer
Nov 14th, 2002
We have a supposedly DDR configured 801 router which dials out to the ISP at an average of every 15 secs. This sporadic behaviour also occurs at odd hours btw 10pm and 6am.
I really need to stop the router from dialing out in this manner as the phone bill is rather too high.
Following is the running config of the 800 router.
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname bcmrouter
enable secret 5 $1$cC/A$wQoTZGIV5/itbbMxeHIbf/
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
process-max-time 200
interface Ethernet0
ip address 192.168.0.2 255.255.255.0
no ip directed-broadcast
ip nat inside
interface BRI0
ip address negotiated
ip nat outside
encapsulation ppp
dialer idle-timeout 300
dialer string 08450798202
dialer hold-queue 10
dialer load-threshold 180 either
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname bcm
ppp chap password 7 04550A125E2E424F05
ppp pap sent-username bcm password 7 082F4D5A58160B161E
ppp multilink
ip nat inside source list 100 interface BRI0 overload
ip nat inside source static tcp 192.168.0.1 25 212.188.176.118 25 extendable
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 BRI0
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 deny udp any any eq netbios-ns
access-list 100 deny udp any any eq netbios-dgm
access-list 100 deny udp any any eq netbios-ss
access-list 100 permit tcp any any eq www
access-list 100 permit tcp host 192.168.0.1 any eq smtp
access-list 100 permit tcp host 192.168.0.1 any eq domain
access-list 100 permit ip host 192.168.0.1 any
access-list 100 permit ip 192.160.0.0 0.0.0.255 any
dialer-list 1 protocol ip list 100
line con 0
transport input none
stopbits 1
line vty 0 4
end
The last line in your access-list 100 is going to activate the dialer for any traffic not explicitly denied in the previous statements. That's probably where your problem lies. If the connection is used just for internet access remove the
and add
access-list 100 permit tcp 192.168.0.0 255.255.255.0 any eq 443
access-list 100 permit tcp 192.168.0.0 255.255.255.0 any eq ftp
access-list 100 permit tcp 192.168.0.0 255.255.255.0 any eq (any other ports you really need)
This should eliminate your unwanted dialer activations. You can of course modify the access list to your particular needs.
Bob
FINNITTO Thu, 11/14/2002 - 08:41
I have re -edited the access-list as below, (ignore the access-list 1)
I realise that without the last entry of '100 permit ip host 192.168.0.1 any' no one can access the internet. The 192.168.0.1 is the proxy server.
What else do I need to add to allow http traffic and remove last line on access-list?
FINNITTO Thu, 11/14/2002 - 09:03
the line that reads
is all that's needed to permit web traffic. For DNS lookups you may want to add
access-list 100 permit udp host 192.168.0.1 any eq domain
for secure web site access you will neeed
access-list 100 permit tcp host 192.168.0.1 any eq 443
and that should be it.
I noticed something else that may be causing a little confusion as well. Your using the same access-list 100 as both the nat source and dialer list. Use another list for your NAT. acccess-list 1 would work well for this.
ip nat inside source list 1 interface BRI0 overload
That done, I think everything will work fine.
Bob
