Warning message
IPSec Manual and SPI question
Nov 14th, 2002
Hi all,
We are impelementing IPSec manual site to site because other site doesn't
support IKE. I know that if you implement IPSec manual keying
-- ACL's for crypto map entries tagged as ipsec-manual are restricted to as
single permit entry and subsequent entries are ignored.
-- The SAs established by a manual crypto map entry are only for a single
data flow.
IKE doesn't have any restrictions like that. Is this because of IKE
automatically assigns SPI numbers to the other permit entries for the same
access-list. Or is there any other reason?
I know the solution for the IPSec manual restriction of permit entries. I
want to know why is this restriction. Because of one SPI for one permit
entry?
Any help will be really appreciated.
Best regards,
gfullage Mon, 11/18/2002 - 19:56
  • Cisco Employee,
Basically yes. Each line in your ACL actually builds a separate tunnel, with unique SPI's. If you use manual keys, you can only provide one set of SPI's, and therefore, the router/firewall can only build one tunnel, hence only one line in your ACL.
With IKE, it dynamically creates unique SPI's per tunnel/ACL line, and therefore you're not limited.
btimuralp Tue, 11/19/2002 - 00:46
I was expecting this answer, thanks.
Best regards,
