ciscoworks rme 3.1 compatibility
Nov 17th, 2002
Can anybody suggest what is the latest version rme 3.1 support.I recently upgrded my routers with ios Version 12.2(11)T2, RELEASE SOFTWARE (fc1)
and ), Version 12.2(12a), RELEASE SOFTWARE (fc1)
.after upgrading i am not able to manage the routers.in rme configuration management i am not able to get the configs of the router and if i check the device attributes it shows telenet not supported.Can anybody suggest on the above?it's very urgent.
REgards,
Amit.
s.advani Wed, 11/20/2002 - 22:00
Hi mustaq,
The table you suggested gives the minimum ios version but not the higest ios version.Can u suggest on this
Amit.
rmushtaq Thu, 11/21/2002 - 05:51
  • Blue, 1500 points or more
RME requires the min IOS version only. For example if for a device it says that 12.1 IOS is required, then it means 12.1 or later is ok.
