Warning message
How to config 2 NAT translation over two different internet pool?
Nov 17th, 2002
There are two ISP provide service to our company, and they assigned two internet subnets to us ---- 202.101.111.X / 18 and 210.34.111.X / 24, I configed our Cisco 2621 router (IOS 12.2) like this :
-----------------start copy config here ----------------------
interface FastEthernet0/0 ----------- to 1st ISP,a unstable internet connection
ip address 210.34.111.171 255.255.255.0
ip nat outside
no ip mroute-cache
speed auto
full-duplex
interface FastEthernet0/1 ---------- to our intranet
ip address 172.16.5.1 255.255.255.0
ip nat inside
no ip mroute-cache
speed auto
full-duplex
interface Ethernet1/0 ---- to 2nd ISP with stable internet connection
ip address 202.101.111.101 255.255.255.192
ip nat outside
no ip mroute-cache
full-duplex
ip nat pool pub 202.101.111.102 201.101.111.119 netmask 255.255.255.192
ip nat pool cer 210.34.111.171 210.34.111.171 netmask 255.255.255.0
ip nat inside source pool pub overload
ip nat inside source pool cer overload
ip classless
ip route 0.0.0.0 0.0.0.0 202.101.111.65
ip route 210.34.0.0 255.255.0.0 210.34.111.1
no ip pim bidir-enable
access-list 1 permit 172.16.5.0 0.0.0.255
access-list 2 permit 172.16.5.0 0.0.0.255
--------------end of copy config --------------------
I hope the router couldn NAT it base on the route table: to 210.34.X.X net,use cer pool, while to the other host use the pub pool. but I failed : when I try to access a host with IP 210.34.45.217, it go through this way:
172.16.5.22 ----my desktop
172.16.5.1 ---router
202.101.111.102 -- after NAT
210.34.111.171 --- go to the correct port here,but it take about 200ms
210.34.45.217
I believe I should change my config(maybe use route-map...), but I don't know how to do,any help will be appreciate.
d_korman Mon, 11/18/2002 - 01:30
You could associate a route-map with each NAT pool. Use the route-maps to select which pool to use based on appropriate criteria. match IP next-hop might be suitable. Note that the resulting mapping entries are flow-based so cannot be used for incoming connections.
