Warning message
VMS 2.1 ,IDS MC and IDS configuration
Nov 20th, 2002
Hi, I would like to know if it's possible configure signatures on a IDS directly with IDS MC or i must use IDS device Manager. If i have more than 50 IDS and i want to change a global signature i must configure each sigle IDS and it's take long time.I see that in IDS MC there is the possibility to add a lot of IDS on the same group but i can't do anything else.
Many thanks in advance
larrjone Wed, 11/20/2002 - 13:33
In the current release of the IDS MC, you cannot configure signatures at the group level. This is planned for a future release. However, you can configure the signatures for 1 sensor and then use the Copy wizard to copy the settings to multiple sensors. The Copy wizard is located under the Configuration tab.
