thisisshanky Wed, 11/20/2002 - 13:51
  • Purple, 4500 points or more
Its due to cable delay that the distance is limited to 100 ft. The maximum delay specifications for ethernet shudnt exceed 1000 nsec thats 1 microsec. With mathematical equations, it can be found that the maximum distance limitation would be no more than 100 meters. So ultimate reason - cable delay
No.
The origional 802.3 10 base 5 spec was for 500 Meters.
A little used 10 Broad36 supported 3.6 kM over a broadband system.
The 10 Mb and 100 Mb fiber specifications are tipically for 2 KM.
In order to keep costs low, the UTP specifications have been 100 meters.
10 baseT, 100BaseT, 100BaseT4, and 1000BaseT.
The distance limitations on half duplex are either attenuation or timing.
The attenuation factor is how far away can the receiver be until the data cannot be reliably received over the noise.
The timeing is how long can the cable be before 64 bytes are transmitted on one station without the first byte being received on the receiving station. This was used to sense collisions on half-duplex ethernet..
There are some excelent white papers on the web.
Doug
