Warning message
Cisco 4000 4700-M capabilities? T1
Nov 21st, 2002
I have the above mentioned set up in my lab. I need to connect to a T1. Is there a T1 DSU/CSU module available for this series router, or is there another type of adapter or module that I would have to use to make it accessible?
Overall Rating: 4.5 (2 ratings)
thisisshanky Thu, 11/21/2002 - 09:49
  • Purple, 4500 points or more
If its a lab setup, between 2 router, you can use NM-4T module or NM-2T module with 4 or 2 ports respectively, and connect them using a back to back serial cable. The pin is db-60 type
tiredofthis Thu, 11/21/2002 - 10:01
Here is the deal. I have a T1 coming in a day or two. The router that we are going to use is a 4000 series 4700-M. We have upgraded the memory, the only thing missing is the connect for the T1. Will the NM-4T or NM-2T modules work for this?
thisisshanky Thu, 11/21/2002 - 10:05
NM-4T has 4 serial ports while NM-2T has 2 serial ports, each of which can be used for a T1. But each port needs an external CSU/DSU. YOu would need to runa db-60 to v.35 cable from router serial port to the CSU. THe T1 demarc will be connected to the CSU .
router -s0-----serial cable----CSUDSU----Rj45 cable-----T1demarc.
tiredofthis Thu, 11/21/2002 - 10:07
thanks shank, I'll give it a try and let you know how it turns out.
thisisshanky Thu, 11/21/2002 - 10:10
I messed up the part number. Its not NM, its NP.
So the correct part numbers are NP-4t and NP-2t
Apologize for the error.
