Warning message
AS5300 Crashes
Nov 22nd, 2002
This is follow up to my first post on the AS5300 crashes.
It just crashed again. During the time that it was going down, I was unable to extract any information by telling it to show version because it would not allow me to even log in even though I had the terminal up.
The screen was filled with errors that had hex addresses. I was unable to write any down because they were filling the screen. When I hit the enter key to allow me to log in, the message: Unable to create Exec: no memory or too many processes.
My non-Cisco-informed mind leads me to think that we have some bad memory. Is that the case or is there some other things that I should look for?
mljohnson Fri, 11/22/2002 - 11:10
When the router is in the process of crashing, you don' t really need to enter any data; simply try to log whatever info comes to your screen (which will be more with a console connection than a telnet connection). Once the router comes back up, you can then collect "sh stack", and these two pieces of information can get us started on a cause.
I'm not sure if you mean that the "no memory" message came up before/during the crash or after the router booted back up; I assume it is NOT the latter. The message itself hints of a memory leak, but the information above would be required to confirm.
dboutell Fri, 11/22/2002 - 12:31
The massages that were coming across were extremely hard to copy. I got that "no memory" message when I hit the enter key while it was crashing.
This is the show stack, although it has been 3 hours now. Will that help?
User Access Verification
Username:
Username: root
Password:
AS5300>en
Password:
AS5300#sh stack
Minimum process stacks:
Free/Size Name
5704/6000 Reset ipc queue
5600/6000 Microcom DSP download Process
9492/12000 Init
5296/6000 RADIUS INITCONFIG
10480/12000 Mica board Download
5192/6000 Mica slot Download
5456/6000 Modem Autoconfigure
8144/9000 DHCP Client
10764/12000 Exec
5728/6000 Async tty Reset
9920/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
2 4146432 7244/9000 Low IRQ Int Handler
3 53588 7544/9000 High IRQ Int Handler
4 177989 8600/9000 Console Uart
6 0 9000/9000 Parity interrupt
7 3304738 8604/9000 NMI Interrupt Handler
AS5300#
AS5300#
mljohnson Fri, 11/22/2002 - 14:12
Did you power cyle the router? There is no stack dump here...I would guess that "sh ver" says it was started restarted by reload. Regardless, unfortunately there is no information here that will be of help in understanding the cause of the crash.
dboutell Fri, 11/22/2002 - 14:34
Yes, I did power cycle. Am I supposed to wait until it restarts by itself? According to the things that I have read, that could take anywhere from several minutes to several weeks.
tepatel Sun, 11/24/2002 - 09:40
  • Cisco Employee,
stack trace will be lost after you power cycle the router..So when the router reboots by its own and come back up on its own, that time you need to get the "sh stack" (before power cycle) so that we come to know the information about the last crash.
Now here is the url for which you will find more information about how to troubleshoot router crashes
http://www.cisco.com/warp/public/122/crashes_router_troubleshooting.shtml
dboutell Mon, 11/25/2002 - 06:58
Yes, I have read that page, however, in my last post I mentioned the fact that it could take up to several weeks for the machine to reboots on its own and we have experience several hours and it didn't reboot on its own.
I realiize that this operating system requires certain steps being performed in order to collect pertinent information, but I do not have the luxury of waiting until it reboots, in as much as it already has not rebooted, in one instance, in over 4 hours.
We are running Cisco Internetwork Operating System Software
IOS (tm) 5300 Software (C5300-I-M), Version 12.1(7).
I there an updated IOS that might help?
mljohnson Mon, 11/25/2002 - 08:46
If it's taking more than a few minutes, this means that the boot sequence is not completing correctly, or right after the boot sequence completes the router reloads again. This would certainly hint of a HW issue, but again we need more data. Connect a terminal to the console port, and when the router crashes collect the information that is logged to the console port. You only need to do this for 3-5 minutes, tops; at that point you will likely see a pattern start to exist in the output, cycling endlesslessly.
You could also try, at this point, to remove a card at a time to see if that breaks us out of the boot cycle and allows the router to boot up completely (which again should only take a few minutes at the most). If there is a HW issue, this may help to pinpoint it.
Finally, the latest 12.1 code would be fine for the 5300; however, I think you may have a HW issue (not sure how long the router stays up before it will crash again), so upgrading may not make a difference but you can try that nonetheless.
dboutell Fri, 11/29/2002 - 07:45
I have captured a complete crash. Should I post the complete terminal echo from when it first started going bonkers up through the point where I cycled power?
tepatel Sun, 12/01/2002 - 11:36
  • Cisco Employee,
YES..go ahead and post it..
dboutell Mon, 12/02/2002 - 07:03
Here is the entire log from when the AS5300 starts having a probem until it is back up and running after a power cycle.
6d20h: %LINK-3-UPDOWN: Interface Async76, changed state to down
6d20h: %LINK-3-UPDOWN: Interface Async113, changed state to up
6d20h: %SYS-3-CPUHOG: Task ran for 2740 msec (63/46), process = ARP Input, PC = 60303BB0.
-Traceback= 60303BB8 60352448 602EC744 602EC730
6d20h: %LINK-3-UPDOWN: Interface Async18, changed state to up
6d20h: %LINK-3-UPDOWN: Interface Async139, changed state to up
6d20h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async28, changed state to down
6d20h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async18, changed state to up
6d20h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async139, changed state to up
6d20h: %LINK-5-CHANGED: Interface Async28, changed state to reset
6d20h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async18, changed state to down
6d20h: %LINK-5-CHANGED: Interface Async18, changed state to reset
6d20h: %LINK-3-UPDOWN: Interface Async28, changed state to down
6d20h: %LINK-3-UPDOWN: Interface Async89, changed state to up
6d20h: %LINK-3-UPDOWN: Interface Async18, changed state to down
6d20h: %LINK-5-CHANGED: Interface Async27, changed state to reset
6d20h: %LINK-5-CHANGED: Interface Async84, changed state to reset
6d20h: %LINK-3-UPDOWN: Interface Async27, changed state to down
6d20h: %LINK-3-UPDOWN: Interface Async84, changed state to down
6d20h: %SYS-3-CPUHOG: Task ran for 2320 msec (46/17), process = ARP Input, PC = 60303BB0.
6d20h: %LINK-5-CHANGED: Interface Async152, changed state to reset
6d20h: %LINK-3-UPDOWN: Interface Async152, changed state to down
6d20h: %LINK-3-UPDOWN: Interface Async151, changed state to up
6d20h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async151, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2048 msec (47/38), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async93, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async185, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async85, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async85, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2336 msec (58/41), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async166, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async94, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async175, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async94, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async128, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async23, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async23, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async23, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async14, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async14, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2272 msec (61/25), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async2, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async2, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async2, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async2, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async2, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async26, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async26, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async31, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async31, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2344 msec (55/34), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async5, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async20, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async12, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async12, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async182, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async182, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async22, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async17, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async22, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2380 msec (30/19), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async128, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async128, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async170, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async170, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async170, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async5, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async5, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async25, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async25, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async54, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async56, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async54, changed state to reset
6d21h: %SYS-3-CPUHOG: Task ran for 2328 msec (44/17), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async7, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async54, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async15, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async7, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async15, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async143, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2188 msec (42/30), process = ARP Input, PC = 60303BB0.
-Traceback= 60303BB8 603533C8 603524D0 602EC744 602EC730
6d21h: %LINK-3-UPDOWN: Interface Async116, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async116, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async116, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async116, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async116, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async120, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async120, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async173, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async120, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async98, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async98, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async113, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async113, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async86, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async86, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async50, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async50, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async153, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async153, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async153, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async91, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async91, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async11, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async11, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async11, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async20, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async20, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async71, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async71, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async85, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async85, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async85, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async111, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async111, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async149, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async154, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async125, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async125, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async154, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async119, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async45, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async39, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async45, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async45, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async45, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async52, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async45, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async52, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async109, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async52, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async109, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async179, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2200 msec (71/54), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async179, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async179, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async31, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async155, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async31, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async155, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async31, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async155, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async61, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2180 msec (56/44), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async80, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async24, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async24, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async135, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async150, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async135, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async150, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async39, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async39, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2472 msec (66/34), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async165, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async43, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async103, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async191, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async103, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async43, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async103, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async191, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async103, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async37, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async37, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async103, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async37, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async111, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async111, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async111, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async176, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async176, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async176, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async108, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async154, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async154, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async108, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async96, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async184, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async154, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async108, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async96, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async184, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async51, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async133, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async118, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async3, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async118, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async104, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async6, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async6, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async6, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async160, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async160, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2160 msec (64/60), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async188, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async90, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async129, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async90, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async129, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async159, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2172 msec (50/41), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async190, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async190, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async190, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async38, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async180, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async38, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async87, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async127, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async127, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async184, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async184, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async184, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async141, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async38, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async115, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async38, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async38, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async8, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async186, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async180, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async186, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async180, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async186, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async132, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async117, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async117, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async92, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async36, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async88, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async88, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async92, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async3, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async3, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async192, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async134, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async134, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async17, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async134, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async17, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async134, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async69, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async69, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async134, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async104, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async60, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async104, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async60, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2112 msec (56/36), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async46, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async69, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async127, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async69, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async127, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async69, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async127, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async181, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async56, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async56, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async181, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async123, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async148, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async174, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async123, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async136, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2740 msec (24/17), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async157, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async157, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async174, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async157, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async174, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async102, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async102, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async166, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async166, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async173, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async173, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async142, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async64, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async178, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2448 msec (51/38), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async95, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async95, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async100, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async53, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async126, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async19, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async19, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2128 msec (44/33), process = ARP Input, PC = 60303BB0.
-Traceback= 60303BB8 60353324 603524D0 602EC744 602EC730
6d21h: %LINK-5-CHANGED: Interface Async93, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async143, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async93, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async143, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async4, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async4, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async130, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async131, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async131, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async87, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async131, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async81, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async87, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async130, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async81, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async78, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async78, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async43, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async43, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async43, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async57, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async130, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async130, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async57, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async130, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async57, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async168, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async57, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async57, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async29, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async13, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async13, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async161, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async183, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async79, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async183, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2784 msec (96/75), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async60, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async162, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async60, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async60, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async59, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async59, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async58, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async58, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2828 msec (85/44), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async44, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async115, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async115, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async72, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async72, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async156, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async156, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async107, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 3004 msec (54/19), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async79, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async79, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async76, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async28, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async28, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async18, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async18, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async18, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async18, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async18, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async15, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async15, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async15, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async27, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async27, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async84, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2636 msec (86/35), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async4, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async152, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async4, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async4, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async59, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async94, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async59, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async59, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async64, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async64, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2624 msec (52/26), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async80, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async80, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async14, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async14, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2660 msec (47/39), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async26, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async23, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async1, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async1, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async12, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async98, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async98, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async182, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async12, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async98, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async68, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async8, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async8, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async148, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async22, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2648 msec (34/29), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async148, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async128, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async170, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async5, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async54, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async7, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async7, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async61, changed state to reset
6d21h: %SYS-3-CPUHOG: Task ran for 2584 msec (52/46), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async61, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async136, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async136, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async44, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async44, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async113, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async29, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async29, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async120, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async120, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2512 msec (40/39), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async128, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async91, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async91, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async153, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async153, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async58, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async58, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async58, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2504 msec (54/48), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async142, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async142, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async71, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async71, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async68, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async119, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async12, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async68, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async119, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async179, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async179, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async32, changed state to reset
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async32, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async32, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async16, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async16, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2056 msec (81/54), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async100, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async155, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async100, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async155, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async135, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async144, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async135, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async135, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async144, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2136 msec (66/60), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async181, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async181, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async181, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async192, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async147, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async192, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async147, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async191, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2584 msec (74/62), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async63, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async147, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async147, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async37, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2184 msec (66/3), process = ARP Input, PC = 60303BB0.
-Traceback= 60303BB8 60353380 603524D0 602EC744 602EC730
6d21h: %LINK-3-UPDOWN: Interface Async147, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async37, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async35, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async53, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async35, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async53, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async71, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2388 msec (76/21), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async176, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async108, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async108, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async96, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2376 msec (72/39), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async81, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async81, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async81, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async65, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async65, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async65, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2444 msec (43/24), process = ARP Input, PC = 60303BB0.
6d21h: %MICA-3-MODEMBAD: Modem number 2/24 is bad, Error code is FFFFFFFF
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async72, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async72, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async72, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async144, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async144, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async118, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async144, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async178, changed state to reset
6d21h: %SYS-3-CPUHOG: Task ran for 2672 msec (72/35), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async178, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async6, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async189, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async76, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async189, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async76, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async48, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async48, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async48, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 3968 msec (108/52), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async160, changed state to up
6d21h: %LINK-5-CHANGED: Interface Async63, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async129, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async63, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2528 msec (31/16), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async84, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async46, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async84, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async46, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async190, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async27, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async27, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async27, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async140, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async140, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2796 msec (69/21), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-5-CHANGED: Interface Async21, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async21, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async83, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async83, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async83, changed state to down
6d21h: %SYS-3-CPUHOG: Task ran for 2840 msec (59/50), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async158, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async105, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async158, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async78, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async78, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async78, changed state to down
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async180, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async117, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async186, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2556 msec (50/29), process = ARP Input, PC = 60303BB0.
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async3, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async151, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async151, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async151, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async10, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async10, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async167, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async10, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async10, changed state to reset
6d21h: %LINK-5-CHANGED: Interface Async167, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async10, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async167, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async132, changed state to reset
6d21h: %LINK-3-UPDOWN: Interface Async132, changed state to down
6d21h: %LINK-3-UPDOWN: Interface Async30, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async30, changed state to up
6d21h: %LINK-3-UPDOWN: Interface Async157, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2772 msec (92/62), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async67, changed state to up
6d21h: %SYS-3-CPUHOG: Task ran for 2796 msec (79/27), process = ARP Input, PC = 60303BB0.
6d21h: %LINK-3-UPDOWN: Interface Async131, changed state to up
6d21h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async95, changed state to down
6d21h: %LINK-5-CHANGED: Interface Async95, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async130, changed state to up
6d22h: %LINK-3-UPDOWN: Interface Async95, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 2996 msec (75/41), process = ARP Input, PC = 60303BB0.
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 1504 bytes failed from 0x602F2974, pool Processor, alignment 0
-Process= "PPP manager", ipl= 0, pid= 65
-Traceback= 602F5CC8 602F8128 602F297C 602F3170 602FDBE4 6047C0E0 602EC744 602EC730
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async57, changed state to up
6d22h: %SYS-2-CFORKMEM: Process creation of Exec failed (no memory).
-Process= "TTY Background", ipl= 0, pid= 22
-Traceback= 60317590 6030AA74 6025B314 6025BB40 6026F324 6026F7E8 602700E8 602702A8 60289658 602EC744 602EC730
6d22h: %LINK-5-CHANGED: Interface Async130, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async130, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async30, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async30, changed state to reset
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 12000 bytes failed from 0x6031C13C, pool Processor, alignment 0
-Traceback= 602F5CC8 602F7158 6031C144 60317508 6030AA74 6025B314 6025BB40 6026F324 6026F7E8 602700E8 602702A8 60289658 602EC744 602EC730
6d22h: %LINK-3-UPDOWN: Interface Async30, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async146, changed state to reset
6d22h: %SYS-2-CFORKMEM: Process creation of Modem Autoconfigure failed (no memory).
-Traceback= 60317590 6030AA74 6078BFC8 6026F5D0 602700E8 602702A8 60289658 602EC744 602EC730
6d22h: %LINK-3-UPDOWN: Interface Async146, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async38, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async38, changed state to reset
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async158, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async158, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async38, changed state to down
6d22h: %LINK-3-UPDOWN: Interface Async158, changed state to down
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 126 bytes failed from 0x602F823C, pool Processor, alignment 4
-Process= "IP Input", ipl= 0, pid= 36
-Traceback= 602F5CC8 602F7D08 602F8244 60424BA4 600456EC 602BB44C 60389204 6037C3A0 6037D0D4 6037B9C0 6037BBBC 6037BD48 602EC744 602EC730
6d22h: %LINK-5-CHANGED: Interface Async17, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async17, changed state to down
6d22h: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
6d22h: %LINK-5-CHANGED: Interface Async43, changed state to reset
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async43, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async141, changed state to reset
%SYS-3-CPUHOG: Task ran for 2472 msec (153/104), process = ARP Input, PC = 60303BB0.
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 6000 bytes failed from 0x6031C13C, pool Processor, alignment 0
-Traceback= 602F5CC8 602F7158 6031C144 60317508 6030AA74 6078BFC8 6026F5D0 602700E8 602702A8 60289658 602EC744 602EC730
6d22h: %LINK-5-CHANGED: Interface Async42, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async43, changed state to down
6d22h: %LINK-3-UPDOWN: Interface Async141, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async49, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async49, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async42, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async73, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async49, changed state to down
6d22h: %LINK-3-UPDOWN: Interface Async73, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async20, changed state to reset
6d22h: %LINK-5-CHANGED: Interface Async190, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async20, changed state to down
-Process= "Serial Background", ipl= 0, pid= 7
-Traceback= 602F5CC8 602F7158 6031C144 60317508 6030AA74 6049DF58 6049E1C8 6004EF54 602EC744 602EC730
6d22h: %LINK-3-UPDOWN: Interface Async190, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async7, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async7, changed state to reset
6d22h: %LINK-5-CHANGED: Interface Async116, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async7, changed state to down
6d22h: %LINK-3-UPDOWN: Interface Async116, changed state to down
%SYS-3-CPUHOG: Task ran for 2256 msec (94/63), process = ARP Input, PC = 60303BB0.
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async57, changed state to down
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 144 bytes failed from 0x602F8194, pool Processor, alignment 0
-Process= "AAA Accounting", ipl= 0, pid= 70
-Traceback= 602F5CC8 602F7920 602F819C 6079A248 60258188 60254040 602EC744 602EC730
6d22h: %LINK-5-CHANGED: Interface Async67, changed state to reset
6d22h: %LINK-5-CHANGED: Interface Async57, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async67, changed state to down
6d22h: %LINK-3-UPDOWN: Interface Async57, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async117, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async117, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 2028 msec (64/33), process = ARP Input, PC = 60303BB0.
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async109, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async109, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async109, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async165, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async165, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async88, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async88, changed state to reset
6d22h: %SYS-3-CPUHOG: Task ran for 2176 msec (46/12), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-3-UPDOWN: Interface Async88, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async56, changed state to reset
6d22h: %LINK-5-CHANGED: Interface Async5, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async56, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async5, changed state to down
6d22h: %LINK-3-UPDOWN: Interface Async5, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async89, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async89, changed state to down
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 113 bytes failed from 0x602F823C, pool Processor, alignment 4
-Traceback= 602F5CC8 602F7D08 602F8244 60424BA4 6047DC74 604A24DC 604D9148 604DF3BC 602BB44C 60389204 6037C3A0 6037D0D4 6037B9C0 6037BBBC 6037BD48 602EC744
6d22h: %SYS-3-CPUHOG: Task ran for 2428 msec (84/24), process = ARP Input, PC = 60303BB0.
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async28, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async28, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async28, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 2748 msec (60/16), process = ARP Input, PC = 60303BB0.
6d22h: %SYS-3-CPUHOG: Task ran for 2872 msec (38/5), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-5-CHANGED: Interface Async157, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async157, changed state to down
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 65540 bytes failed from 0x602F2974, pool Processor, alignment 0
-Process= "MM/CSM Event Bkgnd", ipl= 0, pid= 56
-Traceback= 602F5CC8 602F8128 602F297C 602F3170 601471C4 602EC744 602EC730
6d22h: %SYS-3-CPUHOG: Task ran for 3180 msec (102/61), process = ARP Input, PC = 60303BB0.
6d22h: %SYS-2-MALLOCFAIL: Memory allocation of 112 bytes failed from 0x60690480, pool Processor, alignment 0
-Process= "IP SNMP", ipl= 0, pid= 59
-Traceback= 602F5CC8 602F7920 60690488 6066D38C 6066D320 60680504 603B16D0 602EC744 602EC730
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async24, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async24, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async24, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async184, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 3388 msec (59/12), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-5-CHANGED: Interface Async184, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async184, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async50, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async50, changed state to reset
6d22h: %SYS-2-CFORKMEM: Process creation of Async tty Reset failed (no memory).
-Traceback= 60317590 6030AA74 6049DF58 6049E1C8 6004EF54 602EC744 602EC730
6d22h: %LINK-3-UPDOWN: Interface Async50, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async160, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async160, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async34, changed state to reset
%LINEPROTO-5-UPDOWN: Line protocol on Interface Async45, changed state to downync34, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 3664 msec (86/34), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-3-UPDOWN: Interface Async45, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async176, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async176, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 3260 msec (50/2), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-5-CHANGED: Interface Async168, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async168, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 3800 msec (33/1), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-5-CHANGED: Interface Async41, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async41, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 3700 msec (106/59), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-5-CHANGED: Interface Async122, changed state to reset
6d22h: %MICA-3-MODEMBAD: Modem number 2/25 is bad, Error code is FFFFFFFF
6d22h: %LINK-3-UPDOWN: Interface Async122, changed state to down
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async6, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async6, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async6, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 4004 msec (68/6), process = ARP Input, PC = 60303BB0.
6d22h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async97, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async97, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async97, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async114, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async114, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 3756 msec (43/0), process = ARP Input, PC = 60303BB0.
6d22h: %LINK-5-CHANGED: Interface Async55, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async55, changed state to down
6d22h: %LINK-5-CHANGED: Interface Async111, changed state to reset
6d22h: %LINK-3-UPDOWN: Interface Async111, changed state to down
6d22h: %SYS-3-CPUHOG: Task ran for 4440 msec (61/2), process = ARP Input, PC = 60303BB0.
System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
AS5300 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x151c9c
Self decompressing the image : #################################################################################################### [OK]
%SYS-4-CONFIG_NEWER: Configuration from version 12.1 may not be correctly understood
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
program load complete, entry point: 0x80008000, size: 0x4d1258
Self decompressing the image : ####################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 5300 Software (C5300-I-M), Version 12.1(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 23-Feb-01 00:22 by kellythw
Image text-base: 0x60008948, data-base: 0x6082C000
cisco AS5300 (R4K) processor (revision A.32) with 65536K/16384K bytes of memory.
Processor board ID 17920911
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.1, Item Number 800-2544-3,
Board Revision D0, Serial Number 17920911,
PLD/ISP Version 0.0, Manufacture Date 8-Mar-2000.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
192 terminal line(s)
8 Channelized T1/PRI port(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
no firmware download for 1/8: does not exist!
Press RETURN to get started!
00:00:18: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:18: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2, changed state to down
00:00:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3, changed state to down
00:00:21: %LINK-5-CHANGED: Interface Ethernet0, changed state to administratively down
00:00:21: %LINK-5-CHANGED: Interface Serial0, changed state to administratively down
00:00:21: %LINK-5-CHANGED: Interface Serial1, changed state to administratively down
00:00:21: %LINK-5-CHANGED: Interface Serial2, changed state to administratively down
00:00:21: %LINK-5-CHANGED: Interface Serial3, changed state to administratively down
00:00:34: %SYS-5-CONFIG_I: Configured from memory by console
00:00:36: %SYS-5-RESTART: System restarted --
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 0, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 1, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 2, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 3, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 4, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 5, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 6, changed state to up
00:00:36: %CONTROLLER-5-UPDOWN: Controller T1 7, changed state to up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 0 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 1 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 2 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 3 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 4 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 5 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 6 timeslot 24 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 1 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 2 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 3 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 4 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 5 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 6 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 7 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 8 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 9 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 10 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 11 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 12 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 13 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 14 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 15 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 16 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 17 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 18 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 19 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 20 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 21 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 22 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 23 is up
00:00:36: %DSX0-5-RBSLINEUP: RBS of controller 7 timeslot 24 is up
00:00:36: %DSX1-6-CLOCK_CHANGE: Freerun clock is now selected as clock source
00:00:36: %DSX1-6-CLOCK_CHANGE: Controller 0 clock is now selected as clock source
00:00:38: %DSX1-6-CLOCK_CHANGE: Controller 2 clock is now selected as clock source
00:01:07: %DSX1-6-CLOCK_CHANGE: Controller 1 clock is now selected as clock source
00:01:08: %DSX1-6-CLOCK_CHANGE: Controller 0 clock is now selected as clock source
00:01:16: %MICA-5-BOARDWARE_RUNNING: Slot 1 is running boardware version 2.0.2.0
00:01:16: %MICA-5-BOARDWARE_RUNNING: Slot 2 is running boardware version 2.0.2.0
00:02:08: %LINK-3-UPDOWN: Interface Async12, changed state to up
00:02:08: %LINK-3-UPDOWN: Interface Async8, changed state to up
00:02:09: %LINK-3-UPDOWN: Interface Async1, changed state to up
00:02:10: %LINK-3-UPDOWN: Interface Async3, changed state to up
00:02:11: %LINK-3-UPDOWN: Interface Async5, changed state to up
00:02:12: %LINK-3-UPDOWN: Interface Async11, changed state to up
00:02:13: %LINK-3-UPDOWN: Interface Async4, changed state to up
00:02:15: %LINK-3-UPDOWN: Interface Async7, changed state to up
00:02:15: %LINK-3-UPDOWN: Interface Async6, changed state to up
00:02:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async1, changed state to up
00:02:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async12, changed state to up
00:02:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async8, changed state to up
00:02:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async3, changed state to up
00:02:17: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async4, changed state to up
00:02:17: %LINK-5-CHANGED: Interface Async11, changed state to reset
00:02:19: %LINK-3-UPDOWN: Interface Async97, changed state to up
00:02:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async7, changed state to up
00:02:21: %LINK-3-UPDOWN: Interface Async9, changed state to up
00:02:22: %LINK-3-UPDOWN: Interface Async11, changed state to down
00:02:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async5, changed state to up
00:02:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async9, changed state to up
00:02:26: %LINK-3-UPDOWN: Interface Async98, changed state to up
00:02:27: %LINK-3-UPDOWN: Interface Async10, changed state to up
00:02:27: %LINK-3-UPDOWN: Interface Async100, changed state to up
00:02:28: %LINK-3-UPDOWN: Interface Async101, changed state to up
00:02:29: %LINK-3-UPDOWN: Interface Async102, changed state to up
00:02:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async10, changed state to up
00:02:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async100, changed state to up
00:02:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async102, changed state to up
00:02:32: %LINK-3-UPDOWN: Interface Async105, changed state to up
00:02:33: %LINK-3-UPDOWN: Interface Async103, changed state to up
00:02:33: %LINK-3-UPDOWN: Interface Async108, changed state to up
00:02:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async105, changed state to up
00:02:37: %LINK-3-UPDOWN: Interface Async107, changed state to up
00:02:39: %LINK-3-UPDOWN: Interface Async106, changed state to up
00:02:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async106, changed state to up
00:02:42: %LINK-3-UPDOWN: Interface Async104, changed state to up
00:02:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async107, changed state to up
00:02:49: %LINK-3-UPDOWN: Interface Async15, changed state to up
