Warning message
GSM 6.10
I am change the unity store codec from G.711 to GSM 6.10 now. Here is my queston :
1.Under the name tab, there are four names option: untiltled,CD quality,Radio Quality,Telephone quality. which one should I choose, or that just a name? Whatever name I save as it will take effect?
2.Under the attributes, which one should I choose,8,000KHz,8 bit mono or the others?
