Warning message
2950s and TACACs
Nov 27th, 2002
When I check device attributes with RME I get "not supported" for TACACS.
I can login to the switches using the TACACS username/password. Have changed attribute to include tacacs username/password. Have deleted device from inventory and added it back in.
Versions:
RME = 3.4
Campus Manager = 3.2 with IDU 1.0
Any suggestions?
Thanks.
rmushtaq Wed, 11/27/2002 - 13:22
  • Blue, 1500 points or more
If doing a Export to File shows the device credentails correct, then Check Device Attributes have a problem. In that case try dong a CCO Big Toolkit search to see if anything shows up.
