Warning message
Application Launcher with VPN Client 3.6.3
Nov 27th, 2002
How can I set up the VPN Client 3.6.3 to automatically start an application after connect, in this scenario: I have two connection entries: connA and connB.
When I connect with connA I want to start application appA and when I connect with connB i want to start appB. I know that you can manually set this up in the Options meniu, and also that you can set it up in vpnclient.ini . So is there any way to AUTOMATE this? So the application will be picked depending of wich conn entry I use? Just to make it more simple for not so technical people........
Thanks.
gfullage Wed, 11/27/2002 - 15:57
  • Cisco Employee,
There's no way to have a different application start for a different connection, sorry.
