Warning message
Application Launcher - vpn client
Nov 28th, 2002
I am running a script via the application launcher using vpn client ver 3.6
I would like to run the script from the netlogon share on the server that validated the login. i.e. wscript %logonserver%\netlogon\script.vbs
unfortunately the environmental variable %logonserver% does get replaced with the server name.
Does anyone know how to do this , I realise it can be done using "cmd /c ....script.vbs" but i'd prefer not to have the dos box pop up.
thanks
fmeetz Wed, 12/04/2002 - 13:53
  • Bronze, 100 points or more
Sounds like you may need to get with Cisco over this issue to see if it can be accomplished.
