Warning message
isdn backup
Nov 29th, 2002
center use one ISDN line as backup for two remote spke router
we persue a solution: when isdn is used as backup line for one spoke at multilink speed 128k, another router at the same time want to use the backup line too. So is there a way to let the first router free one B channel for the other router?
center router
isdn network
router1 router2
tepatel Fri, 11/29/2002 - 10:00
  • Cisco Employee,
YES..pl. use the dialer profile with "dialer max-link 1" command to restrict the incoming connection for one link only so that you have one channel each reserved for each spoke router..Here is the url for more
http://www.cisco.com/warp/public/131/dialer-max-link.html
Configuring back with dialer profiles
http://www.cisco.com/warp/public/793/access_dial/ddr_dialer_profile.html
yi-chen Sat, 11/30/2002 - 05:32
but I want to use two channels for backup one spoke
and want to release one channel for another spoke when needed
tepatel Sat, 11/30/2002 - 21:26
  • Cisco Employee,
You need to explain in clear detail about when and on what situation you want to free a b-channel..But there is a command "dialer fast-idle" which will disconnect the connection on a b-channel when the line becomes idle for configured length of time, the current call is disconnected immediately and the new call is placed.here is the link that explain more
http://www.cisco.com/univercd/cc/td/doc/product/software/ios11/rbook/rddr.htm#xtocid1536812
