Load balancing with two routers and two circuits
Nov 29th, 2002
What is the best way to get load balancing with two routers and two circuits at each location. Right now I have fail over configured and working, but since I have the circuit in place, I would like to use the second line. No sense in just having it sit around and do nothing.
prafuljaded Fri, 11/29/2002 - 13:32
I didnt get what do u mean by failover.
Are you using Static routing / routing protocol?
jkoepsell Mon, 12/02/2002 - 06:56
hrs or hot router standby. If one circuit or router goes down the other takes over.
ngijare Mon, 12/02/2002 - 02:23
If you have two routers, and two serial links of same speed connecting them, then OSPF or EIGRP will automatically do the load balancing between these two links.
If the links are of different speeds, then you can configure load balancing by using EIGRP. OSPF only does load balancing on equal cost paths.....
Hope this helps
jkoepsell Mon, 12/02/2002 - 06:54
I currently am using these protocols and all traffic goes across one link. The links are of equal costs. what in the config does the load balancing. can you give me an example config that uses two routers two circuits and uses load balancing between the two.
ROBERT WATSON Mon, 12/02/2002 - 07:59
your HS or hsrp configurations are preventing load balancing if you disable the feature the eigrp protocol will calculate the metric of each link and balance for you provided that both routers are using the same eigrp as.
rais Mon, 12/02/2002 - 08:00
  • Silver, 250 points or more
You can use multigroup HSRP. You can divide the destination network into two destinations or have some of your hosts use the second router as the next-hop.
Thanks.
