Bandwidth report on Router's serial interface ?
Answered Question
Dec 1st, 2002
I have 60 access routers (2611) located at remote sites. These 60 access routers are connected back to HQ using point-to-point serial link. I need to monitor only the BANDWIDTH used in these serial link, then produce a weekly report on the bandwidth utilisation. How can I do this in CW2K LMS 2.0 and RWAN 1.2 ? Pls help, thanks.
Correct Answer by rmushtaq about 14 years 8 months ago
CiscoView can be used for this which have a feature of Real TIme Graphs. But since CV does does not have any database, you cannot do any kind of historical trending or save the info but just print them. nGenius RTM is another option, but for routers, you need to have a switch probe available and connected in order to use. MRTG is another option which is a free ware (http://www.mrtg.org)
Overall Rating: 3 (3 ratings)
Correct Answer
rmushtaq Mon, 12/02/2002 - 07:31
  • Blue, 1500 points or more
yuehct Mon, 12/23/2002 - 16:33
You can use IPM to get some useful historical data on the performance of the links. But sad to say it does not produce utilization reports. If you can gather both IPM and MRTG reports, that will be the best.
axfalk Thu, 02/27/2003 - 12:12
Rizwan,
Can you please elaborate on how to generate the Real TIme Graphs on CV?
Thanks.
_ Alex
rmushtaq Thu, 02/27/2003 - 13:30
Open the device in CV. Select the Port/Interface in the GUI and do a right mouse click. In the menu select Monitor to see the graphs.
szysz Thu, 12/12/2002 - 05:55
You could try JFFNMS an OpenSource Network management system, which includes Bandwidth monitoring and interface autodiscovery and is focused on Cisco Equipment.
It runs on Windows also (prefered is Unix).
You can get reports on the dates you specify, with RTT, PL, Input Rate, Input Packets, Drops, Availability, etc.
The URL is http://jffnms.sourceforge.net
