Warning message
VLANs bridging over ISDN
Dec 2nd, 2002
hello,
I 'ld like to know if it's possible to bridge several IEEE 802.1q VLANS (with a different IP network # for each) over an ISDN line with CISCO2610XM at both end. This is a back-up configuration that'll be awaked manually.
thank
rsissons Mon, 12/02/2002 - 20:04
  • Bronze, 100 points or more
I am not sure that I completely understand what you are trying to do but if you are normally terminating several vlans in a router, and routing IP between them, then the only way you can then bridge that IP traffic over a different interface in the same router, is by configuring IRB, Integrated Routing and Bridging, and that is not supported over ISDN.
yallies Wed, 12/04/2002 - 07:44
thank for your answer, but I think I've to give you more détails.
My customer has a LAN covering two locations linked by an inter-LAN service (Ethernet 100Mb/s from a provider), and several VLANs over this LAN . Communications between VLANs are routed by a 3550-12T on one site.
We wan't to install a back-up solution in case of failure of the inter-LAN link. So we think to an ISDN line withe 2 routers 2610XM, but they 'll have to bridge the VLANs and no to route them because we have the same at each end.
