Warning message
2610 doesn't recognize 2 wic-2T
Dec 4th, 2002
Cisco2610 have 2 wic slots with default.
we installed wic-2t to slot0, slot1 ,but chassis detect only one module.
we installed 1 wic-2t in slot0 and bri in slot1, it works fine.
but wic-2t in slot1 and bri in slot0, it detect only wic-2t.
what is problem? we tested another 2610, but result was same.
rlcarr Wed, 12/04/2002 - 08:57
The 2610 should recognize both WIC-2T cards, I'm doing this successfully in my environment.
If you issue a 'show diag' which wic slot shows a valid module and which doesn't. I would try switching the modules and see if the problem follows the module or the slot.
Merry Christmas & Happy Routing,
~rlc
CCNP, CCDA, CNE
dongjin-kim Wed, 12/04/2002 - 16:16
when I tested with 1 wic-2t to wic slot0 and then slot1, it works fine and
recognized well.
But when I install 2 wic-2Ts both wic slot0: and slot1,
it only recognize wic-2T in slot0:.
