Warning message
350APC and wireless vlans
Dec 5th, 2002
I have a 350 Access point running 12.0T software with a laptop running ACU 5.05 and most up to date drivers. I am getting problems when I am setting up vlans that correspond to ssid. The native vlan appears to work all the time, however when I change the profile to jump into another vlan and do dhcp renew etc I initially get an ip address etc and it says I am authenticated then almost straight away it de-associates the laptop with the message
Disassociating [NETTEAM10]"mac-address" reason "Can Not Support All Requested Capabilities"
this continuously scrolls away, the only way I can get it to work is to set a profile then reboot the access point, and then it only works for approx 10 mins. When I look in Associations it appears that the card always wants to stay in the native vlan even if I deassociate it etc
thanks
btillery Thu, 12/05/2002 - 09:17
What are you using for your network adapter? If Cisco, what firmware, driver, and ACU version are you running?
I've seen this message surrounding the use of TKIP and/or MIC on the AP, however, the adapter in question doesn't support those features.
candv Fri, 12/06/2002 - 01:01
It is an Aironet 350 pcmcia running 8.23 firmware and 5.05 ACU, running on a win98 box, I have also tested it with XP but still no luck, It still seems like the adapter always wants to stay in the native vlan.
thanks
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
