Warning message
LANE: ELAN Number
Answered Question
Dec 9th, 2002
can I use a ELAN-number above 255 for LANE?
Regards.
Volker
Correct Answer by donewald about 14 years 8 months ago
Volker,
Assuming you mean on your sub-interfaces to identify the elan here. No, you cannot. The selector byte is used to identify this and it is only a 1 byte field so you cannot use decimal numbers higher than 255.
Hope this helps,
Don
Overall Rating: 5 (1 ratings)
Correct Answer
donewald Mon, 12/09/2002 - 07:25
  • Silver, 250 points or more
Volker,
Hope this helps,
Don
