Warning message
PPTP from Linux to CVPN 3xxx
Dec 13th, 2002
Has anyone set up a PPTP tunnel from a Linux box to a CVPN? A colleague here at work says he is running into the following problem...
http://pptpclient.sourceforge.net/howto-diagnosis.phtml#ip_loop
He's using the GNU PPTP client.
Anyone have PPTP successfully running from Linux or Free BSD to the CVPN concentrator? Thanks.
gfullage Tue, 12/17/2002 - 21:23
  • Cisco Employee,
Haven't tried it myself, and I know we don't test it, so it may or may not be compatible. Having said that, there's some pretty good workarounds for this problem listed in the URL you supplied, did any of them work for your friend?
