Dialing into a X.25 network
y.lo
I need to make a 3640 router to accept PAD calls and then forward it to a X.25 host over a X.25 network. I use PRI on the 3640 to accept the calls. Does someone have a sample configuration of such implementation? I can't find one in cisco.com. Thanks.
Daniel
raymong
Level 4
Level 4
Here is a link that you might find helpful with a sample config:
http://www.cisco.com/warp/public/116/cmns_x25.html
There are additional sample configs at this link:
