Remote 3508 - Is their a CLI cmd to check if a non-used Gbic is installed?
Answered Question
Dec 15th, 2002
I wish to verify if a 3508 has a Gbic installed in a particular slot. The interface is not in use currently. I would expect a CLI comand would be able to determine this, at least for the purpose of identifying the Gbic H'ware. The device is at a remote location.
Thanks.
Correct Answer by netops01 about 14 years 8 months ago
Yes there is a way.
Do a show interface gi xx and check for media type. It will say media is missing if no gbic installed. If gbic is installed it will say type, SX, LX.
Hope that helps
Ian
Overall Rating: 4 (1 ratings)
Correct Answer
netops01 Sun, 12/15/2002 - 20:37
Yes there is a way.
Hope that helps
Ian
nicolaswatson Mon, 12/16/2002 - 15:08
Thanks for your assistance. The sh int status cmd is not supported on this IOS. The sh int giX command confirmed the media type as SX, therfore installed.
Thanks, Nic.
