Warning message
ISDN Question
Dec 16th, 2002
Router 1-------------Router 2---------------------------------Router 3
----- Lease Line
===== ISDN Backup
Router 1 connected by L.L1 to Router 2 ,
Router 2 connected by L.L2 to Router 3 ,
Router 1 & Router 3 have ISDN Backup
If L.L1 disconnects, Router 1 will start the ISDN Backup which is connected to Router 3.
If L.L2 disconnects, Router 3 will start the ISDN Backup which is connected to Router 1.
My question is that if one of the L.L disconnects say L.L1, and the ISDN starts,
router one will connect itself to Router 3 through the ISDN line, but when Router 2
wants to pass data to Router 1, it won't work because the L.L is disconnected and the
routing table for Router 2 can't change thus it can't pass the data. What are some possible
solution to this problem.
If the diagram of the description of the problem is not clear, please email me and I'll try
to explain it better. Thank you
PS: My customer do not repare dynamic routing ...
uniemeyer Mon, 12/16/2002 - 08:18
You can run a dynamic routing protocol over ISDN but ensure in the dialer-list
that e.g. EIGRP is not allowed to open the ISDN connection.
And also ensure that the metric over the leased lines is better than over ISDN
or the backup won't switch back after the leased line has recovered.
regards Ulrich Marzoli
