12-16-2002 08:03 PM
I have a content engine with Version: ce507-4.0.3. The content engine works fine except that after a period of time about a day the port on the switch (a catalyst 3550) shows as down/down. The port on the switch has no errors. If I removed the ethernet cable and plug it back in to the Content engine it comes back up again. Any ideas on the problem?
I replaced a new content engine and during boot up I get this error:
Dec 16 22:47:29 (none) Diamond: PCI: Cannot allocate resource region 2 of device 00:0d.0
Dec 16 22:47:29 (none) Diamond: PCI: Cannot allocate resource region 2 of device 00:0e.0
Dec 16 22:47:29 (none) Diamond: PCI: Allocation of memory region 00:0d.0/2 (-1609564160 bytes) failed
Dec 16 22:47:29 (none) Diamond: PCI: Allocation of memory region 00:0e.0/2 (-1609564160 bytes) failed
I then did a "show ecdn" and get this message eventhough I have done all that is required.
ECDN content engine is loading, state is no-network, Waiting for network configuration.
ECDN is waiting for network configuration
Please configure your network interface
and set primary interface
For more information, point your browser to CDM 157.128.4.6
12-23-2002 11:57 AM
You will find a quiet a lot of troubleshooting documents on this link.
01-31-2003 02:05 AM
We experienced a slightly similar problem on our 3550. Our port showed down/down but would not come up again until a re-load. We moved the cable to another port and it came up ok. Replacing the cable in its original port proved the same down/down, it seem that the port just stopped working.
MarcusPunter
Cheshire County Council
03-29-2003 10:24 AM
I also meet the same trouble.Someone knows how to solve?
thanks and with regards.
03-31-2003 02:30 AM
could you clarify the problem
- what type of switch ? (is it a 3550 for both of you) ?
- what type of device attached to it on the faulty port ?
- what port speed ? duplex ? auto or static ?
- what software version on the Cat and the other equipment ?
- is the frequency always 1 day ?
Gilles
